| Area: | ProSteel tools | ||
| Subarea: | N/A | ||
In this wiki, we will learn the use of the tool ‘PST Dialogs’ Standard Position’ tool from ProSteel tools.
ProStructures saves the dialog position if it is closed by ‘OK’ button.
Sometimes, due to use of multiple screens or changing the screens, there is a chance of dialog boxes not properly visible on the screen as shown in the image below.
To avoid this issue, this tool can be used which resets all the ProSteel dialog boxes to their standard position.
1. Select the tool and this will restore the position of all dialog boxes to their default position. ( Refer the images below.)
In this way you can restore the positions of all the displaced dialog boxes with the help of this tool.
