| Product(s): | ProStructures, ProSteel |
| Environment: | N/A |
| Area: | 2D Drawing Generation |
| Subarea: | Dimensions |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
Where can you set the spacing of the dimensions ?
In the detail style under Dimensions / General / Distances, the first column is for the longitudinal dimensions.
The second column is for the transverse dimensions.
The last column is for internal measurements.
