| Product(s): | ProSteel | ||
| Area: | Detail Style, 2D Drawing | ||
| Subarea: | N/A | ||
| Original Author | Steffen Knoll, Bentley Product Advantage Group |
There to find the drawing information table and what data can be used for the FRM file.
The drawing information table can be found in the ribbon Drawing Production.
Or of course using the search field in the upper right hand corner.
Every field can be used to fill out a frame file within the drawing.
But for the DetailCenter Express not every field is directly available.
Here the fields marked that are directly accessible in the FRM File.
Following fields are filled out automatically based on settings in the FRM file.
Following fields are used for the DetailInfo block.
That means they are automatically filled with group or single part information based on the object selection in DetailCenter Express.
