| Product(s): | ProSteel | ||
| Area: | Detail Style, 2D Drawing | ||
| Subarea: | N/A | ||
| Original Author | Steffen Knoll, Bentley Product Advantage Group |
The structure of the FRM File is as following:
[HEADER]
Information about the current FRM file, not used for any data transfer
[TITLEBLOCK]
In this block all the information items on the left side can be assigned to a tag in the 2D drawing on the right side of =
[DRAWINGNUMBER]
Here following templates get assigned using any text and variables in the same block below:
DrawingNameTemplate, DrawingNumberTemplate, FileNameTemplate
; frame definition
Here starts the description of all possible fields for the actual frame DGNs followed by
any number of blocks for each frame DGN one.
[A3QUER]
[A2QUER]
All lines starting with ";" will be treated as comment and not taken into account.
