| Product(s): | ProSteel / ProStructures | ||
| Version(s): | V8i / CONNECT Edition | ||
| Area: | Detail Center Express and Drawing | ||
| Subarea: | Drawing border frame and Title Block editing | ||
| Original Author | Sandip Kar, product Advantage Group |
Sometimes user need to use their own customized Template / Title Block for drawimng Frame they are using. To customize the title block one need to understand the following topics.
To know in detail about each section listed above, please follow the below link to download the document with detail explanation.
