| Product(s): | ProStructures, ProjectWise | ||
| Area: | ProjectWise Integration | ||
| Subarea: | ProjectWise Dynamic Managed WorkSpace | ||
The _USTN_DISPLAYALLCFGVARS variable that defined in the Global CSB displays all system level configuration variable and is useful for Administrators during certification and debugging.
1. In ProjectWise Administrator, under WorkSpaces > Managed > Global right-click over the Global Level and select New > Configuration Block.
2. In the New Configuration Block Properties, enter the name PSCE_Global_Config_Variables and the description Global Variables ProStructures CONNECT Edition. Once complete, click Apply.
The dialog title will change to PSCE_Global_Config_Variables Properties.
Note: In the name section underscore ‘_’ (i.e. PSCE_Global_Config_Variables) is not mandatory, one can use blank space also (i.e. PSCE Global Config Variables).
3. Go to the Configuration tab, click on Plus button, and Add the following variable:
Add Variable to the PSCE_Global_Config_Variables CSB -
Name |
_USTN_ DISPLAYALLCFGVARS |
Description |
Display All Configuration Variables (_USTN_DISPLAYALLCFGVARS) |
Add Value |
Operation Type: '='- Assignment Value Type: String Value: 1 |
Locked |
YES |
The final dialog will look like the below image. Once all good, click on the OK button.
Note: _USTN_DISPLAYALLCFGVARS displays all system level configuration variable and is useful for Administrators during certification and debugging.
In this way, we need to create new Global level CSB for ProStructures.
Next Step: Create new "WorkSpace" level CSB called PSCE_Dynamic_WorkSpaceName.
