| Product(s): | ProStructures, ProjectWise | ||
| Area: | ProjectWise Integration | ||
| Subarea: | ProjectWise Dynamic Managed WorkSpace | ||
This is the second step of ProjectWise Integration with the ProStructures application. In this wiki section, we are going to learn how to add/edit ProjectWise CSBs (Configuration Settings Blocks). This can be done in the ProjectWise Administrator, under WorkSpace > Managed.
In this step, we are going to complete the following tasks:
A] Create a new "Predefined" level CSB for ProStructures called PSCE_Configuration_Root.
B] Create a new "Global" level CSB called PSCE_Global_Config_Variables.
C] Create a new "WorkSpace" level CSB called PSCE_Dynamic_WorkSpaceName.
D] Create a new "WorkSpace" level CSB called PSCE_UNITSYSTEM.
E] Create a new "WorkSet/Project" level CSB called PSCE_Dynamic_WorkSetName.
Step 3: Add Exclusions (variables to be excluded from copy-out).
