| Product(s): | ProSteel | ||
| Area: | Detail Style, 2D Drawing | ||
| Subarea: | N/A | ||
| Original Author | Steffen Knoll, Bentley Product Advantage Group |
The drawingpagesymbol gives the possibility for an automatic sheet numbering.
In the titleblock a tag from the frame file needs to be assigned.
The name of the tag in the standard frame files is PG.
Assignment tag "PG" to Drawingpage in the title block.
The last page of DetailCenter Express has a field for the start number.
This will be the drawingpage of the first drawing and then it counts on.
Here the filled out frame of the second detail drawing.
