| Product(s): | ProSteel | ||
| Area: | Detail Style, 2D Drawing | ||
| Subarea: | N/A | ||
| Original Author | Steffen Knoll, Bentley Product Advantage Group |
In this wiki the use of the TITLEBLOCK will be explained.
In General this part of the FRM file has available information on the left side and on the
right side following the "=" the tag from the target frame file can be used to fill out automatically
this information into this tag of the cell.
Setting up Frame Files will be explained in another wiki.
Here only some basics. Frame files have a few requirements:
They consist only of a cell which contains the actual frame, text and the tags.
The name of the cell must be the same as the dgn file.
The name of the tag set must be the same as the dgn file.
The list of attached tags can be shown using the toolbox tags and selecting the cell.
If you are going to create your own frame files it is recommended to use the same field names as in the drawing information table.
So, all these tag names can be used to fill in data like:
ProjectName=NAME1
Most of the information is comming from the drawing information table in the 3D model.
Others come from the second block in the FRM file.
And the last ones, the detail info, comes from the detailed object.
Lets define the sources one by one.
Here a screenshot from the drawing information table with the fields numbered.
FileName - source: FRM file block DRAWINGNUMBER FileNameTemplate
Customer - source: drawing infromation table 3D drawing field 5 Customer
ProjectName - source: drawing infromation table 3D drawing field 1 Project name
ProjectNumber - source: drawing infromation table 3D drawing field 2 Project number
JobName - source: drawing infromation table 3D drawing field 3 Order name
JobNumber - source: drawing infromation table 3D drawing field 4 Job number
DrawingName - source: FRM file block DRAWINGNUMBER DrawingNameTemplate
DrawingNumber - source: FRM file block DRAWINGNUMBER DrawingNumberTemplate
DrawingPage - automatic sheet numbering, see subpage a) Drawing Page Symbol
DrawingIndex - see
DrawingScale - is directly taken from the used detail style
DoneBy - source: drawing infromation table 3D drawing field 6 Marked by
Date - source: drawing infromation table 3D drawing field 9 on
CheckedBy - source: drawing infromation table 3D drawing field 7 Checked at
CheckedDate - source: drawing infromation table 3D drawing field 10 on
ClearedBy - source: drawing infromation table 3D drawing field 8 Approved at
ClearedDate - source: drawing infromation table 3D drawing field 11 on
Specification1 - source: drawing infromation table 3D drawing field 12 LvPos1
Specification2 - source: drawing infromation table 3D drawing field 13 LvPos2
Specification3 - source: drawing infromation table 3D drawing field 14 LvPos3
Specification4 - source: drawing infromation table 3D drawing field 15 LvPos4
Note1 - source: drawing infromation table 3D drawing field 16 Comment1
Note2 - source: drawing infromation table 3D drawing field 17 Comment2
Note3 - source: drawing infromation table 3D drawing field 18 Comment3
Note4 - source: drawing infromation table 3D drawing field 19 Comment4
DetailPosNumber= - PS properties of the detailed single part or group - 1 see screenshots below
DetailShipNumber= - PS properties of the detailed single part or group - 2 see screenshots below
DetailName= - PS properties of the detailed single part or group - 3 see screenshots below
DetailMaterial= - PS properties of the detailed single part or group - 4 see screenshots below
DetailLength= - PS properties of the detailed single part or group - 5 see screenshots below
DetailWeight= - PS properties of the detailed single part or group - 6 see screenshots below
DetailCount= - PS properties of the detailed single part or group - 7 see screenshots below
DetailNote= - PS properties of the detailed single part or group - 8 see screenshots below (it is one field for note 1 and note 2)
DetailFamilyClass= - PS properties of the detailed single part or group - 9 see screenshots below
DetailAreaClass= - PS properties of the detailed single part or group - 10 see screenshots below
