| Area: | ProjectWise Managed Configuration | ||
| Subarea: | ProjectWise Dynamic Managed WorkSpace | ||
This wiki section is created to provide implementation guidance for integration of the ProStructures Configuration dynamically into a ProjectWise Environment. Following are the steps that one need to follow to make ProjectWise Managed Configuration dynamically.
Step 1: Import WorkSpace & Dataset files into ProjectWise through Managed Configuration Import Wizard.
Step 2: Add/Edit ProjectWise CSBs (Configuration Settings Blocks).
Step 3: Add Exclusions (variables to be excluded from copy-out).
Step 4: ProjectWise Application Definition.
Step 5: Upgrade WorkSpace & WorkSet to Work Area.
Step 6: Link CSBs to WorkSets.
Step 7: Add Users.
Step 8: Test/Validate.
