| Product(s): | ProStructures, ProjectWise | ||
| Area: | ProjectWise Integration | ||
| Subarea: | ProjectWise Dynamic Managed WorkSpace | ||
In this step, we are going to link the required CSBs to the ProjectWise WorkSets or ProjectWise Administrative Groups.
1. In the ProjectWise Explorer, locate the WorkSet directory. (For example: pw:\\<server name>:<datasource name>\Documents\PSCE_Managed_Configuration\WorkSpaces\USA_Canada_Metric\Worksets\ExampleMetric), right-click, and get the Properties of this folder.
2. Select the WorkSpace tab.
3. Now, right click on the Predefined level and then click on the Add Association (or double click on the Predefined level).
4. In the Select Configuration Blocks dialog, select PSCE_Configuration_Root and click on the OK button (or double click) to associate the Predefined WorkSpace with the predefined CSB called "PSCE_Configuration_Root".
5. In similar way, associate the below CSBs to respective levels -
* Note: Since the PSCE_Global_Config_Variables CSB contains _USTN_DISPLAYALLCFGVAR, which is often considered an administrative configuration, this CSB could be added to the Administrative User Group instead of the Project. This would make it applicable to only administrative users. See "Link CSBs to Groups" below.
The result should be similar to the image below. (with/without Global_Variables, Personal WorkSpace or optional dataset extensions).
Note: Personal workspace settings allow user-specific workspace configuration for Managed Configurations. By default, you may not have Personal workspace associated if there is nothing defined in your personal workspace, once something is defined in the personal workspace it is automatically associated. To review the contents of your personal workspace CSB, in ProjectWise Explorer file menu select Tool > Options, select the Personal Workspace tab.
Link CSBs to Groups
ProjectWise CSBs can be linked to Groups. For example, since the PSCE_Global_Config_Variables contains _USTN_DISPLAYALLCFGVAR, which is often considered an administrative configuration, this CSB could be added to the Administrative User Group instead of the Project. This would make it applicable to only administrative users. To implement this option, be sure NOT to link the PSCE_Global_Config_Variables to the WorkSet/Project and complete the following steps in the ProjectWise user group.
1. In ProjectWise Administrator, under Groups, select the Administrator, right-click and get the Administrator Properties.
2. Select the Manage WorkSpace tab.
3. Now, right click on the Global level and then click on the Add Association (or double click on the Global level).
4. In the Select Configuration Blocks dialog, select “PSCE_Global_Config_Variables” and click on the OK button (or double click) to associate the Global WorkSpace with the Global CSB called "PSCE_Global_Config_Variables".
In this way, we can link the required CSBs to the ProjectWise WorkSets or ProjectWise Administrative Groups.
Step 7: Add Users.
