now available
ProStructures CONNECT for AutoCAD 2019 / 2020 Update 1
ProStructures CONNECT for AutoCAD Update 1 (10.01.00.05) is now available on Software Downloads.
What's New Highlights
AutoCAD Support
- AutoCAD 2020 and AutoCAD 2019 are supported by ProStructures CONNECT for AutoCAD Update 1.
Operating Systems Support
- Windows 10 (64-bit) and Windows 8.1 (64-bit)
New WiX Installer Technology
- Current release of ProStructures CONNECT for AutoCAD Update 1 works with WIX installation framework which gives a new user experience and various other features.
- Full/Passive/Silent Installation.
Subscription Entitlement Service
- Subscription Entitlement Service is Bentley's improved licensing model, providing enhanced security and optimized value for your Bentley Subscriptions.
- Subscription Entitlement Service integrates the new licensing system with Bentley's Identity Management System (IMS) and the Bentley CONNECT technology platform to allow near real-time reporting of usage, improved notification and messaging to the user, and increased administrative capabilities for organization administrators.
- This product version utilizes CONNECT Licensing, which is not supported by SELECT activation key(s). CONNECT Licensing features new behavior to enhance your organization’s user administration and security with mandatory user sign-in via CONNECTION Client to access the application. If you are already signed in to the CONNECTION Client, you have met this prerequisite. If you have not, please refer to the Administrator's Resource Center and/or contact your administrator for assistance in the registration and sign-in process.
ProjectWise Integration
ProStructures CONNECT for AutoCAD Update 1 supports…….
Supported AutoCAD Version
ProjectWise Version
AutoCAD 2019 & 2020 (64-bit)
10.00.03.280 (Server & Admin) & 10.00.03.334 (Client)
10.00.03.280 (Server, Admin & Client)
10.00.03.262 (Server, Admin & Client)
10.00.03.140 (Server, Admin & Client)
For complete compatibility metrics for design, modeling products see ProjectWise Version Support Matrix
Structural Synchronizer Integration
ProStructures CONNECT for AutoCAD Update 1 is compatible with…
Structural Synchronizer Version
Compatibility
To Download
Structural Synchronizer CONNECT Edition x64 Version 11.01.02.09
No
Structural Synchronizer CONNECT Edition x64 Version 10.01.01.04
No
Structural Synchronizer CONNECT Edition x64 Version 11.00.03.04
Yes
Click Here
Structural Synchronizer CONNECT Edition x64 Version 11.00.00.15
Yes
Click Here
Structural Synchronizer CONNECT Edition x64 Version 10.03.01.06
Yes
Click Here
AutoPLANT Integration
Compatibility
AutoPLANT Modeler CONNECT Edition 10.01.00.067
Yes
AutoPLANT Modeler CONNECT Edition 10.02.00.48
Not Tested Yet
