| Product(s): | ProSteel/ProStructures | ||
| Version(s): | all Versions | ||
| Area: | Manipulation Tools | ||
| Original Author: | Roger Belen, Bentley Product Advantage Group | ||
The ProSteel/Prostructures Connection Editor can be use to modify multiple connections.
You have a model with multiple Shearplates and Baseplate connections that you would like to make some changes and apply to all other connections.
Note: See video below
