Before you begin, please note the following:
Review the End-User License Agreement (or EULA) carefully during the installation of ProStructures. By installing this release, you agree to the terms and conditions of the agreement. A copy of the End User License Agreement named "Eula.pdf" can be found in the folder after installation and can be accessed online at this location http://www.bentley.com/legal/eula_en.txt.
Note: In case you are not able to view the Readme properly in Internet Explorer, make sure you turn off the Enable Protected Mode check box in the Security tab of the Internet Options dialog.
Note: The ProStructures CONNECT Edition Readme is available in multiple languages. Select the desired localized Readme from the Home page of https://docs.bentley.com.
Product |
ProStructures CONNECT Edition |
Version |
v10.00.00.74 |
Language |
English |
