Installing ProStructures CONNECT Edition from CONNECTION Client
 Product(s):ProStructures
 Version(s):CONNECT Edition (10.XX.00.XX)
 Environment:N/A
 Area:Installation
 Subarea:N/A
 Original Author:Kirk Pullin, Bentley Product Advantage Group
Updated By:Vyanktesh Nama, Bentley Product Advantage Group
If a previous release of ProStructures CONNECT Edition is already installed on your computer, you can incrementally download and install a latest ProStructures CONNECT Edition Update from the CONNECTION Client.
The latest ProStructures CONNECT Edition Update will overwrites the previous ProStructures CONNECT Edition release.
You can also control the notifications to perform silent installation of updates from the CONNECTION Client.
Sign into the CONNECTION Client and refer to its help for information on managing notifications and installing application updates.
Steps to be follow
1. Launch CONNECTION Client.
2. In the CONNECTION Client dialog, click on the Update button.
3. Now, check the box for ProStructures CONNECT Edition latest version and click Install Selected.
4. After that ProStructures executable will start downloading.
5. Once 100% download is complete then the ProStructures Installation Wizard will launch.
For further steps on how to configure and install this application, please follow the below wiki-
