| Product(s): | ProSteel/Prostructures, Power ProStructures | ||
| Version(s): | V8i | ||
| Area: | Manipulation Tools | ||
| Subarea: | N/A | ||
| Original Author: | Roger Belen, Bentley Technical Support Group | ||
There are different ways on how you can insert ProSteel Shapes. Knowing how these commands works can help you increase accuracy and speed when working within ProStructures. The video below are just some example of the commands that you can use.
NOTE: When inserting shapes we recommend to insert from LEFT to RIGHT, Bottom to TOP.
