| Product(s): | ProSteel 3D Professional | ||
| Version(s): | 08.11.1x.xx | ||
| Area: | General | ||
| Subarea: | N\A | ||
| Original Author: | Johannes Michalowsky, Bentley Technical Support Group | ||
The Prosteel Data in the part list should show Net weight or Gross weight of elements.
you can also use conditions , here it is Parttype =2 (plates) gives the Net weight, for other elements it gives the Gross weight.
Example
communities.bentley.com/.../BEN_5F00_Singleparts_5F005F00_H_5F00_platenw.zip
for the drawing part list it is available as a field
