| Product(s): | ProSteel 3D Professional | ||
| Version(s): | 08.11.11.55 | ||
| Environment: | Windows 7 64 bit | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
Some or all parts in the part list are missing.
The partlist creation can filter for parts with a position number.
If the number is missing, the part will not be in the database.
The ProSteel properties allow it to switch of the Partlist flag for parts and groups.
Is -In Partlist- box thicked?
There is also an option for parts to be shown in the bolt list.
Here the screenshot of ProSteel properties special parts.
Following two options are very special.
For a common group list it is recommended to switch them off.
Sometimes it is not possible to overwrite an existing mdb file.
If this happens, delete the old file or choose a different name for a new file.
