| | Applies To | | |
| | Product(s): | ProSteel 3D Professional | |
| | Version(s): | 08.11.11.55 | |
| | Environment: | Windows 7 64 bit | |
| | Area: | General | |
| | Subarea: | | |
| | Original Author: | Steffen Knoll, Bentley Technical Support Group | |
How to group a single part list by weight ranges.
The list must already be sorted by the weight.
- Create a new Groupheader with an empty line definition
- First the group condition is requested.
We will use:
if(Partlist.WEIGHT <= 30,1)
for the first range.
- Now insert a new line and give it a title
- As the line has an independent appearance condition use following formula for it:
- For the next range copy and insert the Line Definition 1
- Change the formula for the group condition for the next range:
if(Partlist.WEIGHT > 30 and Partlist.WEIGHT <= 60,1)
as well as the title and the appearance condition
Partlist.WEIGHT > 30 and Partlist.WEIGHT <=60
- Adjust the width for the group headers
- Now the list should be grouped by the set up weight ranges
More weight ranges can be added by repeating step 5 and 6
Product TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
