| Product(s): | ProSteel 3D Professional | ||
| Version(s): | N/A | ||
| Area: | Shapes/Objects | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
Nuts as part of bolts are not listed in drawing part list.
Bolt style nuts not set for partlist
Check bolt style/edit nut data
Tick box for partlist
Update bolts via ProSteel Properties reset bolt style
