| Product(s): | ProSteel 3D Professional | ||
| Version(s): | N/A | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Roger Belen, Bentley Technical Support Group | ||
Prosteel Crashing When Using Partlist Creation Command
This is because the user does not have read/write permission to the file mentioned in the error.
Go into the location of the file mentioned in the error.
In this case.
C:\Program Files\Bentley\ProStructures\V8i_SS5\AutoCAD2013\Localised\English\PartList\Standard Temp.mdb
2. Select file i.e. Standard temp.mdb
Standard temp.mdb > Right click > Make sure the Attributes is not set to Read_only
