| Product(s): | ProSteel 3D Professional | ||
| Version(s): | 08.11.11.55 | ||
| Area: | General | ||
| Subarea: | N\A | ||
| Original Author: | Detlef Hackbarth, Bentley Technical Support Group | ||
It is a bit tricky to store your own templates for drawingpartlists.
Your drawingpartlist might look like this:
In order to store this and create a new template do like this:
1. Store the present template via contextmenue.
2. Define the new template:
3. Beginning from the old template edit the new one (via the "magnify-button") and store it in the subdialogue with command "Save Template As..."
4. Now two templates are available and the second one looks like this:
