| Product(s): | ProSteel 3D Professional | ||
| Version(s): | |||
| Area: | Reports | ||
| Subarea: | |||
| Original Author: | Johannes Michalowsky, Bentley Technical Support Group | ||
In Platenaming and for the partlist, thickness is not appearing as first numeric value
basic Settings in ProSteel Options
open Prosteel Options
go Straight Plates, Plate Description
In Name Description change sequence
$(T) is for Thickness, $(W) Width, $(L) Lenght
