| Product(s): | ProSteel 3D Professional | ||
| Version(s): | N/A | ||
| Area: | Reports/Bill of Material | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
Not all available fields from the drawing information table are provided in reports. How to add additional info such as index using the editor for LST files.
Open the lst template via menu Settings/Edit Part List Definition.
C:\Program Files\Bentley\ProStructures\V8i_S5\AutoCAD 2013\Localised\English\PartList\BEN__header_V.lst
Copy text/variable from one of the header infos
Edit the text by double clicking; change it to Index:
Edit the variable by double clicking; change it to DwgHeader.DrawingIndex
The list of available variables is displayed in the upper left window. Variables can be inserted by double clicking.
