| Product(s): | ProSteel 3D Professional | ||
| Version(s): | N/A | ||
| Area: | Reprots/ Bill of Material | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
The LST file BEN_Singleparts_ordered_list_H groups all parts by the name. For plate that means grouping will be by width and thickness. How to use only plate thickness for grouping.
Go to ProSteel Options Straight Plates/Plate Description.
Change Export description to: $(N) $(T)
