| Version(s): | |||
| Area: | |||
| Subarea: | N/A | ||
| Original Author: | Detlef Hackbarth, Bentley Technical Support Group | ||
In your model you want to see "Identure Numbers" (Positioning Numbers) of your plates and don't know how to do.
In the ProSteel Options at Straight Plates> Plate Label there has to be used the template $(P) with a adequate text size (50) and negative Distance (-100):
In order to display the positioning number of the plate (as a identure number) you need to hook the Part Label in the plates properties:
