| Product(s): | ProSteel 3D Professional | ||
| Version(s): | N/A | ||
| Area: | Reports/Bill of material | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
Reports done by the partlist feature can display all information saved in the mdb file. To make this information visible new columns must be added. This sample is about a new column for the width.
Open LST file in ProStructures Partlist via menu Settings/Edit partlist definition
Double click table to open Table Contents - Partlist
Starting with Header line, copy and insert "length"
Double click new entry and change it to "width"
Fstr$(width,"?&")
