| | Applies To | | |
| | Product(s): | ProSteel 3D Professional | |
| | Version(s): | 08.11.11.55 | |
| | Environment: | Windows 7 64 bit | |
| | Area: | General | |
| | Subarea: | | |
| | Original Author: | Steffen Knoll, Bentley Technical Support Group | |
How to set up objects for first page only.
- The list BEN_Singleparts_cutting_list__V.lst has a picture that is only shown on the first page.
This is handled via layers.
- In case the names of the layers are in a wrong language, they can be changed.
Double click any layer, mark the layer in the upper list and the name can be changed now.
- Switching on first page, the picture is shown in the preview
- To change or set up a layer for an object, you can use the context menu.
- So, the picture will only be visible on the first page.
Product TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
