| Product(s): | ProSteel 3D Professional | ||
| Version(s): | N/A | ||
| Area: | AutoCAD | ||
| Subarea: | |||
| Original Author: | Roger Belen, Bentley Technical Support Group | ||
How to Divide multiple elements using the Element modification Divide tool.
2. The element modification dialog box will open. Click on the Divide button
3. The prompt : Select Objects
4. After Selecting hit ENTER
5. The prompt: Specify point:
6. Specify the reference point you would want to divide the elements.
