| Product(s): | ProSteel 3D Professional | ||
| Version(s): | N/A | ||
| Area: | Modification | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
Cuts between objects can have loglinks. That way it is possible to change the position of one of the objects and the cut will be updated.
Use the -cut part at another part option in Element Modification
Checking PS Properties there is not only the cut but also a loglink
Changing the position of one of the shapes results in an automatic update of the cut
