| Product(s): | ProSteel/ProStructures | ||
| Version(s): | V8i | ||
| Area: | Product Activation | ||
| Subarea: | N/A | ||
| Original Author: | Roger Belen, Bentley Technical Support Group | ||
When working with Prostructures it is a common procedure that you would need to Move/Copy a group of single parts or just a single part.
Within ProStructures there is a tool called ProSteel Copy/Move/Mirror/Align. This command gives you different functionality, one of it is to allow user to MOVE/COPY command either by Single Part or a Group.
See screen shot below for your reference.
