| Product(s): | Prosteel/ProStructures | ||
| Version(s): | All | ||
| Environment: | AUTOCAD | ||
| Area: | N/A | ||
| Subarea: | N/A | ||
| Original Author: | Roger Belen, Bentley Technical Support Group | ||
The Preview option when used in Detail Center is not working.
From the AutoCAD command line type in the comand SDI
The settings should be Set to ZERO "0"
