| Version(s): | N\A | ||
| Area: | Data Export | ||
| Original Author: | Steve Crabtree, Bentley Technical Support Group | ||
Exporting a KISS file from a ProSteel model.
KISS files are quite often needed to produce bills of material.
Generate the KISS file from the model with the PS_Export command. Select the KISS format from the drop down in the figure below
ProSteel only supports the BOM part of the KISS format and only in version 1.0.
