| Product(s): | ProSteel | ||
| Version(s): | N\A | ||
| Area: | Data Export | ||
| Subarea: | N\A | ||
| Original Author: | Steve Crabtree, Bentley Technical Support Group | ||
Exporting NC Data from ProSteel
Have a need to export data files from ProSteel model.
You will be asked to select the objects, select the elements for export or all.
ProStructures Support Solutions
