| | Applies To | | |
| | Product(s): | ProSteel 3D Professional | |
| | Version(s): | 08.11.11.45 | |
| | Environment: | Windows 7 64 bit | |
| | Area: | General | |
| | Subarea: | | |
| | Original Author: | Steffen Knoll, Bentley Technical Support Group | |
Endplate, stiffeners and so on get dimensions. But the dimension lines don't run to the other edge of the group.
Group - additional dimensions
- Here, the stiffeners and the base plate are missing the control dimensions to the other edge of the group or main part.
- Detail style Dimensions/Groups/Reference Points. Set the additional dimensions for all parts to:
Reference part, which is the main part or
Group
Make sure the secondary setting (primary - front view of subparts, secondary - edge view of subparts) is also set accordingly.
- Result is to have complete dimension lines
Product TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
