| Product(s): | ProSteel 3D Professional | ||
| Version(s): | N/A | ||
| Area: | Detailing | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
Workshop drawings of groups display ECS Indicators. How to switch them off?
You have the option to turn ON/OFF and show as Sphere, the ECS axes in the 2D files under ProSteel Options
1. Open Prostructures
2. Go to ProSteel Options > Assembly > Layout > No Display
Note: For the Existing 2D Files you need to Select the Elements > Ps Properties > Assembly > Layout > No Display
