| Product(s): | ProSteel | ||
| Version(s): | N/A | ||
| Area: | Detailing | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
Modifications not displayed in Preview or detail block for single part or group in detail center.
double holes
The most probable reason for this are double holes - the same holes on the same position.
Check all holes in ProSteel Properties of the shape.
Remove all redundant holes.
Update preview or recreate detail blocks.
Open ProSteel Properties of the shape.
Go to General Data/Layout
Tick the box for solid kernel. Using this display mode the 2d output is ok.
