| Product(s): | ProSteel | ||
| Version(s): | N/A | ||
| Area: | Detailing | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
Dimension for holes.
Detail Style option Diameter on Line is on.
But the Diameter is not on the dimension line.
Don't use Hole field reference
Check detail style page Dimensions/Common/Miscellaneous
Set Hole field reference to "without"
