| Product(s): | ProSteel 3D Professional | ||
| Version(s): | N/A | ||
| Area: | Detailing | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
Detailblock created via Detailcenter. Changing a dimension by the grips or stretching, the dimension text stays the same and doesn't change. It should change and display the new distance.
Dimensions in detail style are not set to assoziativ.
Open detail style on page Dimensions/Common
Tick box for -Assoc. Dimensioning
Now dimensions can be changed and the dimension text will be updated
