| Product(s): | ProSteel 3D Professional | ||
| Version(s): | 08.11.11.55 | ||
| Environment: | Windows 7 64 bit | ||
| Area: | Detailing | ||
| Subarea: | |||
| Original Author: | Detlef Hackbarth, Bentley Technical Support Group | ||
You may want to place a coordinate dimensioning manually at your detailed block.
1. The deailblock is created as usual without dimensioning:
2. The detailstyle for the dimensioning is set to "Coordinate dimension":
3. The Measuring dialogue needs to be set to "Alignment: According to line"; first select the requested line, then first and second point of measurement:
