| Product(s): | ProSteel | ||
| Version(s): | 08.11.14.225 | ||
| Area: | N/A | ||
| Subarea: | N\A |
How to create extra Dimension styles for Diameter, Angle and Radius dimensions to set wanted accuracy different from base style.
This elements require a special dimension style name explained in the video.
It needs a suffix added to the dimension style.
The suffix to add to the style name for angle dimensions is $2, for diameter its $3 and for radius its $4.
Click the video below to play it. To view in fullscreen mode, first click the link at the bottom of the video to launch the video in Fullscreen. Then, click the fullscreen button (rightmost button at bottom of video).
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section.
THANK YOU!
