| Product(s): | ProSteel 3D Professional | ||
| Version(s): | N/A | ||
| Area: | Detailing | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
Detailing or previewing a group, some hidden lines are not displayed.
Group property - Display as one part is switched on.
Check ProSteel Properties of the group (Group Data/Data)
If the option -Display as one part is on, switch it off.
Reload Detailcenter.
This option results in a boolean modification which tries to combine all group parts to one element.
