| Product(s): | ProSteel/PowerProStructures | ||
| Version(s): | N/A | ||
| Area: | Detailing | ||
| Subarea: | |||
| Original Author: | Roger Belen, Bentley Technical Support Group | ||
The Display of Hidden Lines can be controlled within ProSteel. This is done by editing the settings of the Detail Style.
Some 2D files does not need to display the hidden lines. One example is the 2D Isometric view of a model. In this exercise you will see that the 2D Isometric View are showing the hidden lines.
1. Edit the Detail Style
2. Under 2D Display > Common > TURN ON/OFF the HIDDEN EDGES settings.
NOTE: For this exercise we will Turning Off the hidden edges.
