Original Question: Orientation and Location Mark by Bernie Malaky
Hello all!
I am not sure of the proper terminology, but how can I label each shape with an orientation/location mark to define in each drawing the shape direction & placement during the fabrication process (single part thru assembly).
Thanks!
Bernie D.
Question: RE: Orientation and Location Mark by Bernie Malaky
….Perhaps what I am looking for is a reference point?
Suggested Answer: RE: Orientation and Location Mark by Johannes Michalowsky
You need to set up the Benchmark Symbol
And it has to be set up in the Detailstyle.
