| Product(s): | ProSteel 3D Professional | ||
| Version(s): | 08.11.11.87 | ||
| Area: | AutoCAD | ||
| Subarea: | N\A | ||
| Original Author: | Jitender Sansoa, Bentley Technical Support Group | ||
User Question: I made Detail Style in attempt to make anchor plan. But final result wasn't as I expected. Anchor plates weren’t magnified at all, although I set in 2DDC/Display/Views/Anchor Plan Sc 1 : 10. Which settings (and where) in 2DDC should be made to get magnified anchor plates in final drawing?
