| Product(s): | ProSteel/ProStructures | ||
| Version(s): | All | ||
| Area: | Manipulation Tools | ||
| Subarea: | N\A | ||
| Original Author: | Roger Belen, Bentley Technical Support Group | ||
When creating a Detail Style for Anchor Plan there are some settings necessary so you can use it to Detail an Anchor Plan.
Create a detail Style that you use for Anchor Plan
2. In this example I will name it as Anchor Plan
Note: Make sure that when copying a Detail Style it is not set as a default or you will not be able to copy it.
3.This will now appear in the list. To make some changes right click on the Anchor Plan detail style and then select Edit Detail Style
4. You may now Edit the Anchor Plan detail Style.
Under 2D Display > Common > Views
Screen shot below shows the settings that you need to have and consider when creating a style for Anchor plan.
5. Once you are done save the Detail Style and you may now use it.
Prompt: Select Main part of the group:
