| Product(s): | ProSteel | ||
| Version(s): | V8i | ||
| Area: | 2D Display - ProSteel Detail Style | ||
| Subarea: | Line Display - ProSteel Detail Style | ||
| Original Author: |
Roger Belen, Bentley Technical Support Group | ||
| Updated By: |
Vyanktesh Nama, Bentley Product Advantage Group |
This section contains the wikis related to Line Display section under 2D Display of ProSteel Detail Style of ProSteel V8i application.
ProSteel for AutoCAD:
ProSteel for AutoCAD uses a file called pro_st3d.lin. This file controls the line types that you can use within ProSteel. The Line type that a user would like to use should be added to this file in order for ProSteel to read and use it.
By default it is located under C:\Program Files\Bentley\ProStructures\V8i_Version\AutoCAD Version\Prg.
