| Product(s): | ProStructures for AutoCAD |
| Version(s): | (08.11.11.207) |
| Environment: | Publishing i-Model |
| Area: | |
| Subarea: | N/A |
| Original Author: | Alistair Lobo, Bentley Product Advantage Group |
Some ProStructures information is missing from the i-Model created by using Bentley's i-Model Composer
You need to download the ProStructures Plug-in for Bentley products (08.11.14.223) and then create an i-Model.
The new i-Model will contain all ProStructures information associated in the parent DGN file.
communities.bentley.com/.../importing-i-model-metadata-into-ms-access
