| Product(s): | ProSteel 3D Professional | ||
| Version(s): | 08.11.11.195 | ||
| Environment: | Windows 7 64 bit | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
Show All is a dialog that enables you to switch all parts in a model to visible.
Following options:
Following display options for ProSteel Features.
Areaclasses
Displayclasses
ProSteel Regen for all manually hidden objects
Following platform display options:
Switching on levels there global display was off.
(If colums are missing, they can be switched by right clicking the header and choosing from the list)
Also levels hidden for the current view will be switched on.
Level unfreeze and unlock
Reset Displayset
Using Shift Key + Right Mouseclick leads to following context menu there objects can
be isolated by Displayset/Set.
Reset Displayset sets this filter back.
