| Product(s): | ProSteel 3D Professional | ||
| Version(s): | 08.11.11.55 | ||
| Environment: | Windows 7 64 bit | ||
| Area: | General | ||
| Subarea: | |||
| Original Author: | Steffen Knoll, Bentley Technical Support Group | ||
Updating the level assignment of ProSteel parts regarding the ProSteel Optoions level settings as well
as the level color setting.
The level settings are generally working for newly created ProSteel parts.
So older models, models from another version or another office can be different so that ProSteel parts have a different
level assignment and level have a different color assignment.
Starting the tool one can select parts that should be updated. All ProSteel parts get then the correct level assigned.
In a second step all levels will get the preset color assignment.
